U4GM Shares Best Way to Acreage Cluster Jewels in PoE 3.26
Сообщение Smsnaker235 » 16.09.2025, 11:21 »
Cluster Jewels are some of the best able and tradeable jewels in Path of Exile. They add accomplished new acquiescent clusters and generally change how a body works. Because of that, accepting a abiding accumulation of Cluster Jewels can acceleration up your appearance and armamentarium abounding upgrades. The easiest, best repeatable way to acreage them in 3.26 is to accomplish Delirium encounters accord you ample accolade counts, aback Delirium rewards frequently accommodate Cluster Jewels PoE 1 Currency .
How Delirium Mirrors Accomplish Jewels Drop
Delirium mirrors add a fog that spawns added monsters and fills accolade confined as you kill. Each time a accolade bank fills, you get boodle from that tier. The added accolade tiers you reach, the added Cluster Jewels you can get from a distinct map. Run the mirror, break in the fog, and accumulate the beat growing to advance out abounding accolade drops per map. This is the amount artisan you will exploit.
Pick Unending Nightmare on the Atlas
The Album antecedent Unending Nightmare makes Delirium fog never achromatize in maps you run with that keystone. With this antecedent active, the Delirium mirror’s fog stays until you accomplishment the map, so you can ample abounding accolade tiers in one run. In practice, Unending Nightmare turns Delirium from a abbreviate timer into a assiduous band you can acreage for clusters, which is why it is axial to the method.
Use Scarabs to Turbocharge Rewards
Scarabs change how Delirium behaves. Use Delirium Scarabs that acceleration accolade beat bushing (Mania) and those that add Delirium encounters (Paranoia) to hit added accolade ticks per map. Assemblage Mania with Paranoia and add body or added accolade scarabs (for archetype Legion or Abyss scarabs) to accession both abundance and the cardinal of accolade tiers you reach. Scarabs are the multiplier that turns a appropriate Delirium map into a Cluster crop machine.
Make It Work: map choice, bright speed, and routes
Pick maps that are accessible to bright bound and that let you run about the mirror while befitting monsters spawning. Bright acceleration affairs because faster clears beggarly added maps per hour and added mirrors you can run. Use compact, high-density maps and avenue so you can ample accolade confined fast. Some players brace assorted Delirium scarabs and run high-tier maps in bound routes to aerate clusters per hour. This adjustment is repeatable and scales with advance in scarabs and album passives.
Sell for Bill and Accumulate the Best
Cluster Jewels can be awash or used, and they generally accompany abiding returns. If you plan to cast clusters, clue bazaar prices and advertise acceptable rolls at the appropriate time. If you appetite to armamentarium added runs, catechumen a allocation of your booty into Poe 1 Divine Orb by affairs the best clusters or key uniques you find. Investing some PoE 1 Currency aback into scarabs and maps usually raises your abiding yield. For abounding players this aeon becomes a reliable assets loop.
Get Delirium mirrors, set Unending Nightmare on the Atlas, assemblage Mania and Paranoia scarabs, aces fast bright maps, and acreage the accolade tiers. Advertise the best Cluster Jewels or accumulate the ones that fit your build. With a focused avenue and abiding investment, Delirium agriculture delivers a reliable breeze of Cluster Jewels and the bill to accumulate the agent running.
Smsnaker235
