MMOEXP Aion 2 Starter Guide: Aerial Exploration, PvE Focus,
Сообщение Joenwalker » 20.05.2026, 09:18 »
1. Overview: What is Aion 2?
Released in Korea and Taiwan on November 19th, 2025, Aion 2 is NCSoft’s ambitious contender for "MMORPG of the Decade." Unlike its predecessor, which focused heavily on PvP, this sequel shifts toward PvE while retaining the franchise's trademark: flying.
Engine: Unreal Engine 5
World Size: 36x larger than the original Aion
Global Release: Planned for second half of 2026 Aion 2 Items
Current Status: Testing phase in Asia to determine what works for Western audiences.
Key Metric: Earned €58 million in its first two months, with player numbers still growing.
2. The Core Gameplay Loop: What Makes Aion 2 Different?
Flying & Vertical Exploration
You are not just walking from A to B. Your wings let you explore vertical layers—above, below, left, right. This makes the world feel alive and larger than typical MMOs with ground-only mounts.
Hybrid Action Combat
No more tab-targeting. You must actively aim and dodge.
Combat is compared to Black Desert Online or Blade and Soul, but with its own rhythm.
You switch between ground and aerial combat mid-fight.
Criticism: Animations can feel rigid; dodge rolls sometimes lag or jump into attacks. Camera jitter may cause motion sickness for some buy Aion 2 Items .
PvE Focus (Major Shift from Aion 1)
~200 instanced challenges (though many are visually similar tower challenges).
4-player dungeons with multiple difficulty levels for daily grinding.
8-player raids – the only source of the best PvE gear. Boss fights require active dodging, timing, and combo chains.
Ascension Trials: Solo PvE mode with wave-based combat and class leaderboards.
PvP: Completely Optional
Open-world PvP is gone. You will not get ganked while questing unless you toggle PvP on.
The Abyss: A permanent PvEvE zone where anyone can attack you at any time. Guilds coordinate here for top-tier loot.
Middle Reshanta: High-end mandatory PvP zone where factions fight over fortresses.
Joenwalker
Байк: no
