Unstoppable Loadout Build for Black Ops 6: Reckoning Easter
Сообщение sunshine666 » 14.08.2025, 08:51 »
If you have attempted the Reckoning Easter Egg in Black Ops 6’s Zombies mode, you already know how brutal it can be. Between armored enemies, wave after wave of specials, and a finale that pushes teams to their limit, success requires more than just good aim. It demands a loadout that blends bo6 custom bot lobby survivability, firepower, and utility. Through community testing and high-level gameplay feedback, one loadout stands out above the rest—an overpowered configuration that turns even the toughest encounters into highlight reels.
Let us break it down step by step.
Primary Weapon: Pack-a-Punched Grav Assault Rifle
The Grav rifle is not the flashiest gun in Black Ops 6, but it is secretly one of the most effective for Reckoning. Once Pack-a-Punched, its rate of fire and high base damage allow it to tear through hordes with little effort. Paired with the Brain Rot ammo mod, it becomes a one-man army, turning enemies against each other and clearing space in the most chaotic firefights.
Attachments that focus on recoil control, ADS speed, and increased magazine size give the Grav all it needs to dominate.
Secondary: Ray Gun Mark III or Monkey Bombs
While the Ray Gun Mark III returns in a modified form, its crowd control ability is unmatched. Fire the alternate blast to create time-freeze zones, which help during holdout objectives and boss fights alike. Combined with the primary fire's splash damage, this wonder weapon becomes indispensable.
If you do not have access to the Ray Gun, Monkey Bombs fill in as an elite choice for your secondary slot. Not only do they deal high damage, but their distraction effect gives you precious seconds to reposition or revive teammates.
Best Field Upgrade: Aether Shroud or Energy Mine
Although Ring of Fire is a common pick, Aether Shroud offers superior utility for solo players or support roles. It allows you to escape tight situations instantly, especially useful when carrying quest items or moving through high-traffic zombie zones. Max it out to get two charges and a longer duration.
Energy Mine is ideal for players defending objectives. The upgraded version chains electric damage across enemies, wiping out entire lines of zombies with a single placement.
Recommended Perks
You will want to go beyond the basics here. In addition to Juggernog and Speed Cola, the full perk spread should include:
Death Perception – Reveals nearby enemies through walls, essential during dark indoor sequences.
Tombstone Soda – Prevents complete loadout loss if you go down during key phases.
PHD Slider – Greatly reduces explosive damage, which is critical if you are using splash-heavy weapons like the Ray Gun.
Stamin-Up – Absolutely necessary for mobility and running objectives across Reckoning’s large map.
Support Tools: Sentry Gun and Chopper Gunner
In the final stages of the Easter Egg, support tools can make or break your run. The Sentry Gun works great when defending points or controlling a chokepoint. Save the Chopper Gunner for the final boss—triggering it at the right moment can shave off massive health bars and give your team breathing room.
Tactical & Lethal Picks
Frost Blast grenades help slow down fast elites, while Frag Grenades or Thermite are best for clearing out high-health enemies. Keep a decoy grenade or two for tight scenarios where your team needs to res.
sunshine666
