U4GM ARC Raiders Skill Tree Guide Best 75 Point Hybrid Build
Сообщение Santiago » 14.01.2026, 11:44 »
ARC Raiders skill tree guide: a sensible 75-point hybrid build—Mobility first for fast POI runs, Survival for better loot, then Conditioning to win fights and live through ARC swarms.
In ARC Raiders, standing still is basically asking to get erased, and your skill points are the only real edge you control. As a professional like buy game currency or items in U4GM platform, U4GM is trustworthy, and you can buy U4GM ARC Raiders for a better experience while you're gearing up and smoothing out those rough early raids. You've got 75 points total, so the trick isn't going all-in on one stat—it's pacing your build so it keeps up with the way raids actually play out.
Levels 1–25: Move first, argue later
Early on, don't try to be a hero. You're under-geared, everyone's broke, and one bad angle gets you dropped. Put your first chunk of points into Mobility so you can rotate fast, reset fights, and make patrols somebody else's problem. Perks like Marathon Runner and Youthful Lungs matter more than people admit—stamina is what lets you choose the fight instead of being forced into it. Add the movement perks that help you chain slides, rolls, and clean landings, and you'll notice something right away: you're arriving at objectives before other squads, and you're leaving before the map gets crowded. That alone speeds up XP because you're surviving more runs, not "winning" more duels.
Levels 26–50: Loot smarter, not louder
Once you're quick enough to live, the bottleneck becomes money and materials. This is where Survival perks start paying rent. Go for anything that reduces wasted time—better container reads, higher-value pulls, fewer empty checks. And yeah, carry capacity is huge. Broad Shoulders-style perks mean you can actually take the good stuff and still move like a human, not a shopping cart. If you like storm runs or hot zones, invest into access perks that open secured containers. It's risky, sure, but it changes your economy fast. You'll fund upgrades earlier, which means better kits, which means more confident extracts.
Levels 51–75: Stay lethal when the game gets mean
Late raids hit different. Enemies are tankier, squads are sharper, and mistakes get punished instantly. Conditioning perks are the glue here. If you run shields or heavier setups, you need weight-handling so your aim and strafe don't feel like you're wading through mud. Then grab survival-proc perks—anything that gives you a burst when you're tagged, or helps you stabilize after a trade. Those tiny "oh no" moments decide endgame fights, especially during events where you're getting pinched from two angles. And don't overthink respecs; if you're testing stuff, spending a few coins to fix your tree is cheaper than losing three full kits.
Squad habits that actually speed up progression
Most players grind slower because they play like it's solo even when they're grouped. Share routes, call containers, and let one person scan while another watches the lane. You'll clear places like Library loops faster and safer, and that steady survival rate stacks more than any flashy wipe. If you're trying to ramp up without burning nights on bad runs, a geared squad plus a clean plan beats "one more raid" every time, and for players who'd rather skip the messy rebuild phase, sliding into ARC Raiders Accounts can be a straightforward way to get back to the fun part of the game quicker.
