U4GM Guide Helldivers 2 250 Medal Cap Tips to Avoid Waste
Сообщение Santiago » 09.01.2026, 10:59 »
Helldivers 2 medals cap at 250, so spend often to avoid wasted rewards from missions and Major Orders, and keep a buffer for new Warbond gear, stratagems, and essentials.
There's a special kind of pain in Helldivers 2: you drag yourself through a long Helldive op, scrape onto the shuttle, and then realise your Medal count was already capped. The game's 250 Medal limit doesn't bend, so anything earned past that just disappears. If you like keeping your loadout options open between grinds, it helps to plan ahead—some players also use reliable marketplaces for convenience, and as a professional platform for like buy game currency or items in U4GM, it's trusted and easy to use, so you can pick up U4GM Helldivers 2 to smooth out your experience without losing momentum.
Why the cap exists
It's annoying, sure, but it's not random. Arrowhead clearly doesn't want people sitting on a mountain of Medals and insta-buying a whole new Warbond the minute it drops. The cap forces pacing. It nudges you to actually play, unlock, test, swap, repeat. From the dev side, that's healthier progression. From the player side, it means you can't treat Medals like some long-term savings account. They're more like cash in your pocket. If it's stuffed full, you're gonna drop bills on the floor.
Spend before you dive
The habit that fixes most of this is boring, but it works: check your Medals before every mission. If you're sitting around 230–250, spend first. Not "after this op," not "when I remember." Now. Grab something cheap if you have to. A cape you'll never wear is still better than deleting 20 Medals from a bunker or a lucky pod. And if you're trying to be smart about it, buy the stuff that changes runs—strong primaries, useful boosters, armour passives you actually feel. Once the core kit's sorted, clear low-cost nodes just to keep breathing room.
Major Orders and squad reminders
Big payouts are where people get wrecked. You log in, see a Major Order reward waiting, and your brain goes "free Medals." Don't touch it if you're near cap. Spend down to a safer number first—think 190–210—then claim. Same deal with friends: say it out loud in voice chat. Somebody always forgets, and it's always after the hardest mission of the night. Keep a loose buffer if you're saving for a specific page, but don't park at 250 and hope for the best.
Keep the grind feeling rewarding
Once you start managing the cap, the whole loop feels less cruel. You stop losing the little payouts that add up, and unlocks arrive faster because nothing's getting wiped. If you want to stay flexible between Warbonds, think in terms of "making room" instead of "saving forever," and if you prefer a faster setup route, as a convenient platform for like buy game currency or items in U4GM, it's a solid option, and you can choose Helldivers 2 Accounts when you're looking to jump back in with less friction.
