U4GM ARC Raiders What to Buy First to Snowball Coins
Сообщение Santiago » 07.01.2026, 11:06 »
Max out stash space early, push workbench and hideout upgrades, and spend coins on clutch consumables so every ARC Raiders run pays out harder instead of bleeding profit on bad vendor buys.
When you first start grinding ARC Raiders, Coins feel like water slipping through your fingers. One bad spend and you are back in junk gear getting deleted in two hits, while other players seem to snowball ahead. Before you even think about flashy legendaries, you need a basic plan for where your money goes, the same way you would plan a budget in real life or when you decide whether to grab extra supplies from U4GM instead of wasting time. The goal is simple: spend on upgrades that keep paying you back, not on short‑term toys that get thrown away after one unlucky raid.
Why Stash Space Comes First
The stash upgrade line looks boring on paper, but it quietly decides how rich you can get. You start with 64 slots, and that fills up fast, usually after a single decent run. There are ten stash levels, each adding 24 slots. The early ranks are cheap, around 5k Coins, but later tiers jump up hard, ending at 200k for the final stretch and roughly 575k total. That sounds brutal, so do not rush the full line straight away. Aim for Level 5 first, which gives you 160 slots for around 55k in total. At that point you can hold Bobcat mods, Jupiter parts, and stacks of trade goods without panic‑selling them just to clear room. Once you stop dumping loot early, your stash turns into a mini market, with tech items like Processors sitting there ready for 3k flips or feeding into purple craft recipes that beat vendor payouts by miles.
Workbench, Hideout And Long‑Term Power
After stash upgrades stop choking you, your next big money sink should be the Workbench and Hideout. A Basic Workbench costs about 15k, but it opens Tier II guns such as the Bobcat III, which already gives you a noticeable step up over starter trash. If you can scrape together 50k for the Advanced bench, you unlock the route to Legendaries like the Jupiter, and that is where crafted gear really starts to replace trader stock. Just be ready for upkeep. Top‑tier weapons chew through durability faster, so plan around spending something like 10k a week on Gunsmith repairs if you are running them regularly. On the Hideout side, a Level 3 Generator at 30k does not look exciting, yet the passive Scrap it pumps out cuts your costs later, and Farm plots feeding you ingredients for Adrenaline Shots keep you in good shape without constant vendor trips.
Spending On Gear The Smart Way
When you finally spend Coins on actual gear, do it with survival in mind, not fashion. Consumables are where most of your "emergency budget" should go. Medium Medkits are fine, but Surge Shield Rechargers at around 2k each are the real insurance policy, letting you make mistakes and still walk out of a raid. Arc Grenades are worth stacking too, especially if you like staggering tougher enemies or creating safe windows to reposition. Check each vendor reset for things like Extended Mags or Stability Grips, but do not go wild buying every shiny attachment. Use solid base weapons such as the Tempest rifles to bridge the gap until your crafting tiers catch up. Avoid dropping cash on armor unless you are truly desperate; purple armor turns up often enough in the field that paying full price for it usually feels bad a day later.
Adapting Your Budget As You Progress
Your priorities should shift as your account grows. Early on, most players do well putting roughly sixty percent of their Coins into stash levels and basic benches, because storage and core crafting speed up everything else you do. As you move into mid and late game, more of your budget can slide into quality‑of‑life stuff: Augments like Safe Pockets for around 10k, which protect your high‑value loot if a raid goes sideways, or Hatch Keys that open contested extracts where the real money sits. Safe Pockets in particular pay themselves off the moment you pull out a 15k Rocketeer drop that would have been lost. Once your core systems are online, every Coin you spend should either help you survive more runs, unlock better crafts, or squeeze extra profit out of each raid, just like how you would think twice before buying random things instead of targeted upgrades or curated ARC Raiders iteams.
