Efficient Routes Through the Sekhemas Trial: Floor-by-Floor
Сообщение Santiago » 25.11.2025, 10:07 »
Efficiently navigating the PoE 2 Trials of Sekhemas requires strategic planning and understanding the layout, objectives, and challenges of each floor.
Floor 1: The Entry Challenge
Focus on speed and minimal combat engagement to conserve Honour.
Quickly clear mobs while avoiding optional fights or traps.
Prioritize disabling death crystals or completing straightforward objectives.
Grab any defensive Relics early to prepare for later floors.
Floor 2: Increasing Complexity
Expect more traps and combined enemy waves.
Use mobility skills to avoid area damage and conserve Honour.
Pick off ranged enemies first to reduce Honour drain.
Utilize Relics that boost resistances or Honour recovery if available.
Floor 3: Environmental Hazards and Puzzles
Navigate complex layouts with spike traps and cursed grounds.
Clear ritual casters swiftly to stop enemy summons.
Use boons or crowd control mechanics to control difficult enemy waves.
Maintain awareness of Honour levels; retreat and choose safer clear paths if low.
Floor 4: The Gauntlet Trial
Face large waves of enemies under time pressure.
Use area damage skills for efficient clearing.
Coordinate Relics and boons emphasizing damage mitigation.
Position carefully to avoid overlapping damage effects.
Floor 5: The Hourglass Trial
Survive continuous enemy waves for a set duration.
Keep high mobility to dodge attacks.
Use healing or Honour restorative buffs tactically.
Manage resources conservatively to endure the full timer.
Floor 6: Preparation for Bosses
Opportunities to gather powerful Relics and boons.
Clear remaining enemies in safer paths.
Optimize Honour and resource pools.
Focus on buffs that enhance survivability and damage output.
Floor 7: Boss Encounters (including Rattlecage)
The most challenging fight requiring precision and endurance.
Use all defensive abilities and Relics to mitigate heavy damage.
Maintain constant Honour to avoid instant failure.
Prioritize dodging and exploit boss attack windows for maximum damage.
General Tips for Efficiency
Use movement skills to keep pace, avoid damage, and complete rooms quickly.
Adapt your route depending on Honour status; safer paths if low.
Manage Relic slots and boons dynamically based on floor challenges.
Learn enemy attack patterns to reduce Honour loss.
Consider group play to speed runs and increase survivability.
Following this floor-by-floor approach helps preserve your Honour, optimize resource use, and ensures steady progression through the Trial of the Sekhemas with minimal setbacks. It balances speed, safety, and effective combat to unlock full Ascendancy rewards.
