How Simulacrum Splinters Lead to the Big Rewards in PoE 2
Сообщение Santiago » 22.10.2025, 10:10 »
Simulacrum Splinters are the currency that unlocks the pinnacle Delirium encounter in PoE 2, and understanding how they convert into big rewards is key to efficient farming.
What Splinters are and how they’re used
Splinters are the drop currency tied to the Delirium/Simulacrum activity. They are farmed from high-difficulty delirium zones and the Simulacrum itself, and they’re the gateway to access or push deeper Delirium content.
A full Simulacrum run requires a large pile of Splinters to enter and sustain through the 15 waves. As you accumulate more Splinters, you unlock more opportunities for higher-tier Delirium content and richer rewards.
Why Splinters matter for loot and progression
Entry scaling: More Splinters allow you to enter more runs or push into deeper Delirium layers within the same session, increasing your odds of encountering lucrative drops and endgame currency.
Reward density: The rewards you get from Simulacrum runs scale with difficulty and depth. Higher Splinter-enabled runs can yield better currency drops, crafting components, and potentially unique items tied to high-end builds.
Trading leverage: Splinters can be traded or converted for other resources, giving you flexibility to target specific gear paths, invest in map juicing, or fund upgrades.
Best practices for maximizing Splinter farming
Focus on high-yield maps and Delirium zones: Prioritize zones and maps known to produce more Splinters per run, especially at higher delirium intensities where drops are more valuable.
Balance risk and reward: Deep dives into Simulacrum are lucrative but punishing. Ensure your defenses, sustain, and mechanics handling are solid before attempting the deepest levels to avoid costly failures.
Use efficient run setups: Develop a repeatable, fast-clear strategy that minimizes downtime between runs. The faster and safer each session, the more Splinters you accumulate over time.
Track ROI: Keep a simple ledger of Splinters gained, runs completed, and the loot value obtained. If ROI dips, adjust map selection, party composition, or the depth you attempt per run.
Group play considerations: In a team, coordinate Splinter targets and loot priorities. Shared strategy can boost overall drop rates and reduce downtime between runs.
