Farming the Ancient Crisis Fragment in Path of Exile 2 requires a well-planned strategy focused on increasing your Waystone Drop Chance and efficiently clearing Iron Citadel maps. The Ancient Crisis Fragment is a critical item dropped by the boss in the Iron Citadel a high tier map necessary for unlocking The Burning Monolith.
To maximize your drop rate, focus on boosting the Waystone Drop Chance, a stat that directly influences how many Crisis Fragments you get per run. The key to this is carefully rolling your Waystones to have six suffix modifiers by using Vaal Orbs, which can corrupt a Waystone to have all suffixes. Only suffix modifiers improve the drop chance of Crisis Fragments. Aim for a Waystone Drop Chance of around 300%-400% to consistently earn two fragments per Iron Citadel. Increasing this chance beyond 750%-900% can yield three fragments per run, though such high numbers require specialized setups and strong builds to handle tougher map mods.
Optimizing your Atlas Passive Tree is equally important. Invest in nodes that increase Waystone Modifier effects and quantity to enhance the overall farming efficiency. Precursor Tablets that provide increased Waystone quantity also greatly complement your farming efforts.
Choose your Iron Citadels wisely and repeatedly run them along the edge of the Atlas maps to find these rare locations efficiently. Keep a speed farming build ready to maintain quick clearing times, since Citadels can be challenging, especially with high-drop-chance modifiers that apply negative effects like reduced life recovery or increased monster damage.
Given the guaranteed Crisis Fragment drop from the boss once defeated, consistent and fast runs with the right setup lead to accumulation of multiple Ancient Crisis Fragments, which are vital for unlocking pinnacle endgame content. This farming approach not only maximizes fragment drops but also ensures you can sustain long farming sessions with steady rewards.
Maximize your Waystone Drop Chance by crafting six-suffix Waystones, enhance your Atlas passive for Waystone bonuses, run Iron Citadels efficiently with a fast farming build, and consistently defeat the faction boss to farm Ancient Crisis Fragments effectively. This method is the most reliable route to accumulating these rare and valuable fragments for endgame progression.
