Simulacrum Splinters: How to Acquire & Use Them Wisely
Сообщение Santiago » 09.10.2025, 10:06 »
Simulacrum Splinters in Path of Exile 2 are key currency items required to access the challenging Simulacrum encounter.
How to Acquire Simulacrum Splinters:
Simulacrum Splinters primarily drop from Delirium encounters scattered throughout the Atlas of Worlds. Wherever a Delirium icon appears, defeating enemies and bosses in these areas gives chances for splinter drops.
Instilling maps with Delirium using Distilled Emotions boosts splinter drop rates as well.
Players can also find splinters through trading or from the Currency Exchange NPC available after Act 3.
Collecting 300 Simulacrum Splinters allows you to combine them into a full Simulacrum item, which opens portals to the Simulacrum gauntlet.
Using Simulacrum Splinters Wisely:
Decide on the difficulty of the Simulacrum encounter by selecting the number of splinters (50 for Normal, 100 for Cruel, 150 for Merciless). Higher difficulty offers better rewards but is more challenging.
Accumulate splinters steadily by focusing on Delirium-infested maps with high monster density to maximize drops.
Avoid wasting splinters on runs if your build or gear isn’t ready, as higher difficulty Simulacrums can be punishing and reduce overall efficiency.
Manage splinter use based on your farming goals—use lower splinter counts for practice or leveling and save larger stacks for lucrative farming runs once prepared.
Pair your Simulacrum runs with good gear and consumable planning, as surviving longer waves leads to better rewards.
Acquiring Simulacrum Splinters revolves around farming Delirium encounters on the Atlas, boosting drop chances by map instillation, and leveraging trade when possible. Using them wisely means matching splinter investment to ability and goals, ensuring efficient access to one of PoE 2's most rewarding and challenging endgame activities.
