Path of Exile 2 Tips: Best Practices to Collect the Cowardly
Сообщение Santiago » 30.08.2025, 09:58 »
To efficiently collect the Cowardly Fate in Path of Exile 2, follow these best practices:
Run Inscribed Ultimatums at the Right Level: Aim to run Ultimatums with an area level around 76 or higher. This balances the difficulty of the challenges with quality rewards, making it possible to farm Cowardly Fate fragments without excessive risk.
Optimize Your Build: Prioritize mobility, area-of-effect damage, and survivability. High movement speed helps to quickly navigate trial zones and avoid deadly attacks, while AoE clears groups fast. Defensive layers like life, energy shield, or evasion improve sustainability during boss fights and tricky encounters.
Choose Favorable Tribulations: Before each trial round, you pick one of three tribulations—negative modifiers that increase difficulty but improve loot rewards. Select the ones that suit your build and playstyle, avoiding those that drastically slow you down or add overwhelming hazards.
Focus on Completing Full Runs: Rather than rushing, aim to complete full Trial runs consistently to secure the highest rewards. Failing runs causes you to lose all accumulated loot, so avoid taking excessive risks.
Use Map and Waystone Mods: Apply map modifiers and select waystones that boost item rarity and quantity. This maximizes your chances of dropping valuable fragments and currency like Cowardly Fate.
Manage Inventory and Economy: Sell excess fragments, soul cores, and currency regularly to keep funds flowing. Efficient inventory management allows for continuous farming without downtime.
Target Uxmal, The Beastlord: Cowardly Fate is specifically dropped by Uxmal, the boss in round 10 of the Trial of Chaos. Refining your strategy against Uxmal—understanding his attack patterns and exploiting weak phases—increases your chance of obtaining Cowardly Fate each run.
Following these practices maximizes farming efficiency, balancing speed and safety, and ensures steady acquisition of Cowardly Fate fragments. This fragment is key for unlocking The Trialmaster and advancing your endgame progression. Consistent runs with optimized builds and smart tribulation choices transform Trial of Chaos farming from a grind into a rewarding and profitable endeavor.
