Crafting for War: Gear Checklists to Dominate Simulacrum
Сообщение Santiago » 14.08.2025, 09:35 »
To dominate the Simulacrum in Path of Exile 2, having the right gear setup is crucial. The Simulacrum arena demands a balance of survivability, mobility, and strong area-of-effect damage to handle waves of challenging monsters and bosses efficiently.
Simulacrum Gear Checklist for Success
1. Weapon
High AoE Damage Output: Look for weapons that boost area damage for quick wave clear.
Attack Speed or Cast Speed: Depending on your build, faster attack or cast speeds increase damage uptime.
Special Mods: Consider weapons with increased elemental damage, critical strike chance, or conversion mods that synergize with your skill.
Uniques that add extra utility or survivability can be valuable for hybrid builds.
2. Helmet
Life and Resistances: Stack as much life and elemental resistances as possible.
Energy Shield: For builds relying on ES, prioritize helmets with high ES and recharge speed.
Modifiers for Damage or Utility: Look for increased spell damage, attack damage, or stat boosts (e.g., intelligence or strength) depending on your build.
Utilities like increased mana regeneration or reflect mitigation can be useful.
3. Chest Armor
High Life and/or Energy Shield: This is often the main defensive layer.
Damage Boosts: Increased damage, area damage, or specific damage types that suit your skills.
Resistances and Avoidances: Elements resist, stun immunity, and dodge/block stats if applicable.
Consider armor with beneficial crafted mods such as increased life regeneration or increased damage taken from reflected sources mitigated.
4. Gloves
Attack or Cast Speed: Speeds improve DPS significantly.
Life and Resistances: As always, survivability remains key.
Quality of Life: Bonuses like increased critical strike chance, elemental damage, or additional effects on hit can enhance clear speed.
5. Boots
Movement Speed: Prioritize boots that maximize your movement speed bonus for dodging and repositioning.
Life and Resistances: Resistances especially to chaos damage and curses help.
Additional Utility: Mods like increased flask effect duration, dodge chance, or reduced freeze/ignite duration are valuable in Simulacrum waves.
6. Rings
Life and Resistances: Essential for increasing toughness.
Damage Penalties Recovery: Rings that add elemental damage, increased critical chance, or modifiers boosting your primary damage type.
Unique Rings: Some unique rings provide critical flasks, damage over time boosts, or offensive buffs that help clear waves faster.
7. Amulet
Life and Resistances: High-value life and elemental resistances are key.
Damage Focused Mods: Increased spell or attack damage, critical strike chance, or elemental damage.
Stat Requirements: Boosts to intelligence, strength, or dexterity as needed for your active gems.
8. Belt
Life and Resistances: High life belts like Leather or Stygian belts with resistances.
Utility Mods: Increased flask charges gained, faster flask recovery, or increased stun and freeze immunity.
Stygian Belts: Can socket a jewel that adds valuable stats for damage or defense.
9. Flasks
Life and Mana Flasks: Recharge quickly with utility mods like instant recovery or increased recovery speed.
Utility Flasks: Freeze immunity, bleed removal, curse immunity, shock removal.
Quicksilver Flask: For maximum movement speed and to aid positioning.
Unique or Crafted Flasks: Flasks that grant additional boosts such as increased damage or defenses.
10. Jewels
Damage Boosting Jewels: Increase critical strike chance, elemental damage, or skill-specific damage.
Defensive Jewels: Life, energy shield, mana regeneration, resistances.
Special Jewels: Those that grant ailments avoidance or additional regen and leech can be critical.
Crafting and Augmentation Priorities
Use Orbs of Augmentation to ensure items have two beneficial mods before upgrading.
Craft life, resistance, and speed mods where possible.
Focus on high item level bases for access to better affixes.
Use vendor recipes for specific utility mods, like movement speed boots.
Aim for synergy between gear pieces, passive skills, and active skill gems.
General Tips
Aim for at least 6,000+ life or 4,000+ energy shield (or a balanced combination) for sturdy survivability.
Maximize elemental resistances close to or at the cap (75% chance to mitigate elemental damage).
Mobility is key—prioritize movement speed and skills to reposition quickly.
Consider Omen of Resurgence to provide a lifesaving second chance.
Balance clear speed with defensive layers—too much offensive focus without defense can lead to quick death.
This checklist emphasizes well-rounded gear suited to the Simulacrum's brutal mechanics, helping you maximize your chances to clear waves effectively and survive longer, especially on higher ranks where difficulty and rewards scale steeply. Combining these gear priorities with smart play and positional tactics will set you up for domination in the Simulacrum arena.
