Crafting the perfect build with Uncut Skill Gems in Path of Exile 2 means strategically selecting active skills that define your playstyle and optimize your character’s strengths. Uncut Skill Gems are the cornerstone of this process, letting you create or upgrade any active skill to tailor your build exactly how you want it.
How Uncut Skill Gems Shape Your Build
Uncut Skill Gems are blank gems you find throughout your journey. Using the Gemcutting menu, you can engrave them into any active skill (attacks, spells, minions, or utility skills), support skill, or buff skill depending on your needs. The level of the Uncut Gem determines the strength or tier of the skill you create or upgrade. This allows you to adapt your build mid-campaign and focus on your ideal playstyle, whether you prefer melee brawling, ranged attacks, devastating spells, or commanding an army of minions123.
Popular Best-in-Slot Active Skills from Uncut Gems
The top active skills to craft from Uncut Skill Gems often align with meta builds and versatile strategies:
Spells:
Frost Bolt and Ball Lightning are prized for cold and lightning builds, offering strong area control and scaling well with support gems.
Contagion is highly regarded for its ability to spread damage across large groups of enemies.
Melee Attacks:
Boneshatter and Earthquake are go-to skills for melee enthusiasts who need heavy-hitting close-range options with strong crowd control.
Ranged Attacks:
Lightning Arrow is a staple for bow users, known for chain or pierce mechanics that clear packs quickly.
Minion Builds:
Raise Zombie, Unearth, and Skeletal Arsonist are prime choices for summoners. Unearth is especially flexible, as it creates corpses for other minion spells and scales through both direct damage and necromancy synergies.
Utility and Curses:
Hypothermia for cold casters debuffs enemy resistance, enabling massive damage spikes when combined with skills like Frost Bolt or Cold Snap.
Tips for Using Uncut Skill Gems Effectively
Early Game: Use Uncut Skill Gems to unlock bread-and-butter clearing skills that suit your class and weapon of choice. Experiment with different skills until you find a setup that feels powerful and enjoyable.
Mid-to-Late Game: Focus on acquiring higher-level Uncut Gems to upgrade your core skills, maximizing their damage, area, or effect duration. Upgrade only what’s central to your build to avoid spreading resources thin.
Meta Adaptation: Save a few Uncut Skill Gems for adapting to boss fights or unexpected challenges. Being able to quickly swap skills or level up a core ability gives you a big advantage in campaign progression and endgame encounters.
Synergy with Support Gems: Once you’ve crafted your ideal active skills, boost them further with compatible support gems—these enhance damage, area, and special effects.
The best active skills from Uncut Gems depend on your build goals, but those able to clear fast, scale with support gems, or provide both offense and defense are consistently at the top of the meta in PoE 2. Take advantage of the flexibility Uncut Gems offer so your build is always optimized for the challenge ahead, whether in solo progression, boss fights, or group play.
