Best Builds for Test of Will Barya: Combat & Honour Tips
Сообщение Santiago » 11.07.2025, 10:27 »
For conquering the Test of Will Barya trial in Path of Exile 2, selecting the right build and mastering Honour management are key to surviving its increased enemy damage and speed. Best Builds for Test of Will Barya
Tanky, High-Sustain Builds
The Test of Will Barya increases enemy damage and speed, so builds with strong survivability excel here. Examples include:
Warbringer (Titan) Block Builds: Heavy armor stacking with life leech and endurance charges provides excellent physical damage mitigation and sustain, making it easier to manage Honour loss.
Invoker Monk: Combines energy shield regeneration with block chance, offering hybrid defenses against both physical and elemental damage.
Summoner Builds: Minions tank damage for you, allowing safer positioning and less Honour loss.
Movement-Heavy Builds
Builds that emphasize mobility can avoid hits more effectively, preserving Honour:
Flicker Strike Builds: High attack speed and rapid movement help dodge enemy attacks and clear rooms quickly.
Whirling Slash Variants: Dash-based melee builds that combine damage and mobility to reduce incoming damage.
Ranged, High Damage Builds with Defensive Layers
Ranged builds that can kill enemies quickly while maintaining defensive layers are strong choices:
Lightning Spear Huntress: High single-target and clear speed with good evasion and resistances.
Lightning Arrow Deadeye: Great clear speed and boss damage, especially when paired with life leech and movement skills.
Honour Management Tips
Maximize Resistances: Balanced resistances reduce damage taken, directly preserving your Honour bar.
Use Defensive Buffs: Skills like Fortify, Molten Shell, or Endurance Charges reduce incoming damage and help maintain Honour.
Maintain Mobility: Avoid standing in one place; use movement skills to dodge attacks and minimize hits.
Leech and Regeneration: Builds with life or energy shield leech help recover health quickly, indirectly protecting Honour by reducing damage overflow.
Relics and Boons: Prioritize relics that increase Honour pool or reduce Honour damage. Boons that restore Honour or increase survivability are invaluable.
Positioning: Stay close enough to enemies to reduce Honour damage per hit but avoid being overwhelmed by multiple attackers.
Combat Strategy
Clear Quickly: The faster you kill enemies, the fewer attacks you take, preserving Honour.
Focus on Single Targets: Prioritize dangerous enemies or bosses first to reduce sustained damage.
Avoid Afflictions: Some rooms have afflictions that increase damage taken or reduce resistances—choose paths that minimize these effects.
Use Crowd Control: Stuns, freezes, or slows can reduce incoming damage and Honour loss.
Choose tanky or mobile builds that can handle increased enemy aggression.
Maximize resistances, life, and defensive buffs to protect Honour.
Use movement skills and positioning to avoid damage.
Prioritize quick enemy kills and crowd control to minimize Honour depletion.
Equip relics and boons that boost Honour or reduce damage taken.
By combining these build choices and Honour management strategies, you can effectively tackle the Test of Will Barya trial’s heightened difficulty and secure its valuable rewards.
