From Noob to Pro: Mastering Support Gem Sockets with Lesser
Сообщение Santiago » 25.06.2025, 05:05 »
Mastering support gem sockets with Lesser Jeweller’s Orbs is a key step for players progressing from beginner to pro in Path of Exile 2. These orbs allow you to add an additional support gem socket to skill gems that already have two sockets, significantly enhancing your build’s power and versatility.
To use a Lesser Jeweller’s Orb, simply right-click the orb in your inventory and then left-click on a skill gem that has exactly two support gem sockets. This action adds a third socket, enabling you to link an extra support gem to your active skill. This socket expansion allows for more complex and powerful skill combinations, boosting damage, utility, or survivability depending on the support gems chosen.
Early in the game, Lesser Jeweller’s Orbs are relatively accessible. You can farm them by defeating monsters and bosses, opening chests, and exploring areas thoroughly. A notable guaranteed source is the basket at the Orok Campfire in the Sandswept Marsh biome, which drops a Lesser Jeweller’s Orb when interacted with. Additionally, vendor recipes and trading with other players provide alternative acquisition methods if farming proves slow.
If you're short on time or want to speed up your progression, you can use poe 2 currency from trades to acquire key resources like Lesser Jeweller’s Orbs more quickly. This is especially helpful for players looking to refine their build without extensive farming.
Strategically, it’s best to use Lesser Jeweller’s Orbs promptly on skill gems with two sockets rather than hoarding them. Adding a third socket early boosts your build’s effectiveness, easing progression through tougher content. Since these orbs stack up to 20, you can comfortably accumulate a supply for multiple gems.
As you advance, remember that Lesser Jeweller’s Orbs only add the third socket; Greater and Perfect Jeweller’s Orbs add the fourth and fifth sockets respectively, but are much rarer and often pricier. If you're planning ahead, securing cheap poe 2 currency through trade or market flips can make acquiring these higher-tier orbs more manageable.
Mastering support gem sockets with Lesser Jeweller’s Orbs involves understanding their function, acquiring them through farming or trading, and applying them efficiently to skill gems with two sockets. This approach empowers you to customize and strengthen your skills early on, setting a solid foundation for more advanced builds as you progress in Path of Exile 2.
