Set pieces have become boring in FIFA over the years
Сообщение MeadeDorian » 06.04.2023, 12:44 »
When to utilize Power Shots: due to the animation taking quite some time to complete FUT 23 Coins , power shots should only be employed when you have enough time and space to carry out the task. Typically, any shot shot within the 18-yard limit will be blocked if the route isn't clearly defined as the trajectory tends to be more flat in comparison to the finesse shots.
Kudos for EA for providing us with the ability to shoot with a new command, especially one that incorporates the ability to aim manually. Also, to turn off the snarky zoom-in effect that is activated when the power shot is activated. Overall, this is an ideal option to shoot.
Set pieces have become boring in FIFA over the years. While free kicks are still uncommon for me However, when you do receive one, they're a lot more dynamic. In addition penalties have been streamlined to improve. Additionally, the corners have not just copied the same mechanics as set pieces, but have a nice new camera view.
Look at the circle of stability that surrounds the ball
Make sure to shoot when the circle is at its narrowest for maximum precision
Press down L1/LB or R1/RB simultaneously as you shoot to perform a finesse or chip shot.
Make use of using the stick on the left to steer the shot before the ball is hit.
Corner kicks will still use the same set of plays that are linked to the D-pad so you have the option of using them buy FIFA 23 Coins for both defensive and attacking scenarios.
MeadeDorian
