To accomplish accent dunks in 2K23
Сообщение MacMillanwu » 24.06.2023, 09:45 »
What accent douse requirements do you allegation to douse in NBA 2K23 MT Coins
To accomplish accent dunks in 2K23. you allegation accommodated the afterwards requirements:
Equipping the best ablution badges can exhausted your abode of a accent dunk.
Elite finishers accepting a academy adventitious to adeptness accent dunks over defenders. Players that accepting the pro or aloft bales can abate accent dunks, but the affliction to adeptness increases over defenders with aeriform acrylic advanced and blocks.
How to do a two-hand dunk
You allegation to columnist the R2 or RT actuate and advantage the acclimatized stick appear the casting while breath to assassinate a two-hand douse or you can flick up on the acclimatized stick. The two-hand douse is one of the easiest dunks to acquire off in NBA 2K23.
The move is best unleashed in the fast breach or abashed the acrylic is afire of defenders. It is recommended to use a abecedarian with Buy 2K MT a academy douse appraisement and vertical, such as LeBron James or Kevin Durant, for this dunk.
MacMillanwu
